-   -   Knock sensor location....please help. (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/knock-sensor-location-please-help-33427/)
kingzero Aug 8, 2009 11:24 PM
So I was replacing the cap and rotor today and noticed a sensor laying on the intake next to the distributor. I looked around online and found it was a knock sensor...which explains why the truck has been sending knock sensor codes. Anyway from the threads I searched some say it is in the block and others say it is in the head. I can't find where it goes. I have already removed my distributor but no luck on finding a threaded hole for it. A specific location would help me out.....back of the head closest to the fire wall or below the exhaust manifold?
It's a 99'
bigdaddykane93 Aug 9, 2009 12:46 AM
It's a 99'
im guessing its on the passenger side head between the spark plugs...
reelbroke2 Aug 9, 2009 06:31 AM
my 95 has 2 knock sensors..there is one in each head both are located in the lower holes
kingzero Aug 9, 2009 10:44 AM
What lower holes...on the side by the exhaust manifold?
kingzero Aug 9, 2009 11:54 AM
2 Attachment(s)
I figured it out and im screwed.....The sensor I found had 1 wire connected to it and it looks like pic 1.
The sensor I found on the back of the block has a 2 wire plug and looks like pic 2.
It seems someone put a 2001 or newer motor in my blazer.......any suggestions?
reelbroke2 Aug 9, 2009 12:15 PM
each head has two threaded ports on the side..yours may have plugs in them
