Late model EGR location
I bought an engine that I was told was a 2001 and upon transfering accessories to new motor, I cant find the EGR valve to hook my exitsting EGR valve connector to. Its not in the usual location up front on the intake manifold. I heard a rumor that it may be internal. But where do you hook up the connector? Any info on this is much appreciated. Thanks, Eric
RE: Late model EGR location
Most likely it was a 2002+ engine. If that is the case, you will have to swap over your lower intake to the replacement motor. You can use all of the other items on teh intake from the replacement, but use the lower intake and your old EGR valve and you should be good to go.
I've never seen the inside of a 2002+ motor. If you wouldn't mind snaping some pictures and noting the differences, that would help out greatly! |
Yeah, thats what i was affraid of. I will have somebody else do the work for me, I was just trying to get as much of the easy stuff done beforehand. Thanks
I thought it was the same til '04. I don't even see an EGR in '04
(307) Thermostat (308) Thermostat Seal (309a) Thermostat Housing - S/T/C/K (309b) Thermostat Housing - M/L/G/H (310) Thermostat Housing Stud (503) Lower Intake Manifold (504) Fuel Meter Body (505) PVC Valve Cover Seal (506) PVC Valve Cover (507) Wire Harness Bracket (508) Wire Harness Bracket Nut (509) Fuel Pipe Bolt (510) Fuel Pipe Nut (511) Fuel Pipe Seal Retainer (512) Upper Fuel Pipe Seal (513) Fuel Pipe Spacer (514) Lower Fuel Pipe Seal (515) Throttle Body Gasket (516) Throttle Body (517) Throttle Body Stud (518) Upper Intake Manifold Stud (519) Fuel Meter Body Seal (533) Upper Intake Manifold (534) Upper Intake Manifold Gasket (700) Fuel Pipes (701) Throttle Position (TP) Sensor Bolt (702) Throttle Position Sensor (703) Idle Air Control (IAC) Sensor Bolt (704) Idle Air Control Sensor (705) Idle Air Co [IMG]local://upfiles/2910/6C5EE3D8F2F9429EA7AC419B4FD31CE6.gif[/IMG] |
I think this change happened the same time that the MFI spider went into use which would have been sometime mid-2002.
I have an '02 that left the dealer's lot in Dec '01 and it does not have the external EGR valve.
You have to remember that the 2002 model year started selling sometime in March-'01. The first few months of production were using up the previous inventory.
Yep, I figured that's why I don't have it. Of course, with my luck they didn't stickthe better spider on mine. :D
