Leaf Spring Shackles
I'm doing it this Sunday so I'll update you guys when I can to let you know how it went.
Wish me luck!
yeah if your bushings arent bad leave that crap alone unless youre going to remove the leaf spring. last time i did rear shackles on a newer body style s10, take off those rear side skirt things so you can get a better swing with the hammer and get air tools in there. sometimes those bolts come out sometimes they dont
FAILURE!!
I tried like hell to get that upper bolt out that goes through the frame and the rubber bushing with no luck! I had some thick gloves on and was banging on the bolt with a small sledge and whacked my finger tip! If I didn't have those thick gloves on I would've been at the hospital right now. Luckily I just tore up the tip a bit.
Before I attempted the job myself I got a quote of $170 just for labor, let's see how much it'll be now!!
if you can break down the rubber portion of the bushing with heat or elbow grease you can separate the sleeve out then collapse the bushing and push it through.
maybe try this.
https://blazerforum.com/forum/articl...-thread-43925/
maybe try this.
Unbelieveable right? It's amazing they lasted as long as they did! What would have happened if they broke while I was driving? Lots of damage?
I'm only 3 blocks from the ocean--damn salt air! In the past 3 months I've put so much money into this truck I could've bought another one! Actually someone was selling a 97 for $1900. I've put over $2000 into mine so far(in 3 months). Only 2 things keep me from getting rid of it--the manual 4wd(little stick)and the woman who I bought it from put a new Jasper mmotor in it and she had a huge stack of receipts for everything she did to it!
