Leaky oil lines
Changed the oil on saturday and found out I have a bad leak in one of my oil lines. Am having them custom made by a local shop to handle 400 psi. Its overkill but it wont leak. In the meantime how hard is it to remove both sets of lines? I havent had the time to really get in there and look. By the way it looks from the oil filter its a bolt on each side. Is that right?
Above the oil filter there is 1 bolt between the 2 lines. The easiest way to get it out is to put several extensions together and have your ratchet at the front of the engine. You can pull the lines along side the engine and out the front. On some blazers you have to take out the motor mount bolt and raise the engine on that side enough to get the lines out. There is a clamp on the lines holding them to the engine that you need to remove. :icon_wink:
