Liftgate window won't lock when closed
Old Jan 23, 2016 | 07:57 PM
MuddyRhino's Avatar
MuddyRhino is on a distinguished road
Default Liftgate window won't lock when closed
Hello all!
Got my 2000 Chevy Blazer LS 2dr 4wd a few days ago, great rig, i love it.
However, when i bought it, i knew about an existing issue with the rear window not opening when pushing the button in both front and back. I figured out it was a disconnected actuator, so i got right to work on fixing it. I manually opened the rear hatch from the inside, took apart the gate panel correctly and reconnected the actuator lever that activates the window locking latch...but now the window will NOT lock when i close it. I watched the latch when closing it, and it goes into position correctly and the latch catches and closes, but won't lock into place like it should.
I didnt mess with any of that area when fixing the actuator, so i'm clueless as to why i'm having this issue....any help?
Old Jan 24, 2016 | 06:03 PM
MoneyPit99BlazerLT's Avatar
MoneyPit99BlazerLT is on a distinguished road
I have had a similar issue in my 99 LT for about a year. Difference is the button in the dash opens the rear window, but the button on the window doesn't open the window. Maybe this discussion will get me going to fix it.
Old Jan 24, 2016 | 06:21 PM
MuddyRhino's Avatar
I went to a pick n pull and got the correct part for my actuator, and after installing it, I noticed what my lock issue was: the lever for the window was bent upward, probably from when I pulled the panel off. It's the level that makes contact with the liftgate handle arm, the section where the gate pull bars meet. So I carefully bent it back into place and bingo, all fixed. Check that out, see if anything is bent or out of place. Hope this helps
Old Jan 24, 2016 | 09:51 PM
richphotos's Avatar
Glad you got it fixed, and thank you for updating us on how you fixed it.
This could help someone with a similar issue down the road.
Old Jan 25, 2016 | 10:19 PM
I fixed mine also tonight. Took the trim off the interior of the liftgate, removed 3 screws that hold the window latch to liftgate, unplugged and removed window latch, then unplugged and removed push button switch from door. Tested continuity on push button, nothing when button was pressed. Installed Wells brand Rear Window Release Switch
Part No SW3465. Works fine now. Thanks for starting some momentum.
red98grandamse
Oct 21, 2011 01:02 PM
Inferno
Jan 21, 2011 11:56 AM
cas
Mar 30, 2010 10:23 PM
Quicksilver
17
Feb 22, 2009 11:23 PM
BlaZeR FXB1581
Jun 14, 2006 02:22 PM
