Limited slip diff ??
Please can anyone tell me how I know how to see what kind of rear diff i have,I
called the dealer, they won't tell me!? Need to know which oil te use, maybe with slip dope? Thanks a lot!! |
If you are wondering about if you have the factory G80, then you are supposed to use regular diff fluid anyway. Check the glove box sticker, look for all of the 3 letter / digit codes. If you find one with G80, you have it. If you do, use only regular diff fluid, as the G80 is a mechanical locker, and does not require any traction modifiers.
Like Tho said check the glove box sticker and post any code you have that starts with a 'G' on here and we can tell you exactly what gearing you have (or at least what came factory).
G80 !!
Thanks, I looked it up, it was readable too! I've found the G 80 code too!
Now I know what to buy. Manny thanks again! Grz from The Netherlands! Hank.:) |
80w90 hypoid gear lubricant.
Thanks for your usefull tips!
Diff has new oil today , I will do the motoroil change too, than later the ATF next week. Thanks again !! Greetings, Hank.:icon_wink: |
| All times are GMT -5. The time now is 02:06 PM. |
