Little coolant drip
99LS 4dr
Flushed out the cooling system last week. Today I noticed about a 2ft discoloration under it in the driveway. Looks like a drip of about 1 drop or less per minute, dead center under the engine. I can't see where it's coming from, but everything around the flush tee and above the water pump (heater hoses, top part of gasket, etc.) is dry. 191k miles, don't know if the pump has been replaced before. Should I even bother just changing the gasket, or put a new pump in while I've got it off? |
If the water pump leaks it most always comes out the hole near the bottom center of the pump. The hole may be hard or impossible to see. Some vehicles it can be seen from the bottom. If the leak has started slowly over time as they ususlly do you should be able to see a stain coming from the pump and going down the lower radiator hose.
The gasket could leak but not likely. |
If it is leaking from the dead center on the front of the engine then it is likely coming from the weep hole in the water pump meaning a new pump is in your future.
If it is about midway or further back then there are a couple other possibilities. The first would be a slow leak running down from the heater core hose fitting exiting the block on the passenger side. The fitting here tends to corrode over time causing slow leaks. The coolant will follow the curve of the engine and drop almost dead center of the truck. The second would be the very common leaking of the intake manifold gasket. The OEM gasket pretty much disintegrates to nothing after a while and the coolant flush may have dislodged gunk that was keeping a leak at bay until it was removed by the flush. Check for coolant in your oil and or a slight odor of burning coolant in your exhaust. Though if a leak in your intake manifold gasket is still small enough these signs may not be detectable just yet. |
If you do swap out the pump you will find that it's a pretty basic job for the home mechanic.
I would go with a new (not rebuilt) water pump. While you are at it... check those hoses and replace the thermostat with a quality unit. I would also look into changing the serpentine belt and tensioner since you have it off anyways... cheap insurance. |
Originally Posted by bandidolenny
(Post 244896)
That doesn't surprise me that they didn't change the "non-leaking at the time" pump... I wouldn't have either. Good luck!
(Post 245061)
Definitely get a new pump and thermostat! Its not that expensive, and it will save you hassle in the long run.
Originally Posted by Confuused69
(Post 245194)
right on man. But just watch it. That is a temporary fix.
| All times are GMT -5. The time now is 05:21 PM. |
