Long Trim Fuel Numbers-Misfire?
Hello Everybody,
I have a 1997 Blazer, 185,000 miles. Vin W. 4 Door, 4WD. I have been watching my Long Trim Fuel Numbers. From what I gather to be perfect at all times they should remain at 0.0 My numbers have been bouncing around quite a bit. My vehicle idles a little rough, but once it starts going it feels fine to me. I have been getting decent gas mileage. 15-16 city 21-23 highway. The other day I had a code go off going down the highway. I had my scanner attached at the same time. P0420. I know this is for the Catalytic Converter Inefficiency. My freeze frame data came up with some way out numbers for the long trim fuel numbers. I did not notice anything different with the vehicle when the light came on. Is this an indication of a misfire? or is there something else going on here? Thanks for any help. Trouble Code: P0420 Abslt TPS % 5.8 ENG Speed RPM 1815 CALC Load % 9.4 MAF Flow GR/SE 18.98 MAP KPA 39 Coolant Temp 188 ST FTRM1 % 0.7 LT FTRM1 % 1.5 ST FTRM2 % 0.7 LT FTRM2 % 0.0 ST FTRM3 % 72.6 LT FTRM3 % -8.0 ST FTRM4 % 65.6 LT FTRM4 % -45.2 Vehicle Speed MPH 61 |
