Low coolant temp
1995 blazer W engine
The truck won’t get above 160-170. Weather has been in the 40s These are the things I have replaced done New radiator and hoses i tried 2 different 195 thermostats new fan clutch both temp sensors,cpu and gauge and tried the bleeding procedure 3 times and I blocked the radiator with cardboard( that does help getting it hotter faster) runs good great heat, iffy MPG13-15 but it’s on a/t 31s with a large roof rack is there anything I’m missing to check? thanks in advance |
Based on what you have replaced and done, perhaps your temperature gauge is not accurate? Do you have a way to measure the temperature? An IR remote thermometer would likely be the easiest and pretty accurate but a thermocouple with a gauge would be good too.
Amazon same day shipping. I’m guessing upper radiator hose or thermostat housing is the best bet for a comparison temp?
Originally Posted by Vinci81
(Post 755745)
I don't know where the temp sensor is located but often they are near or on the thermostat housing. |
The gauge sensor is on the drivers side of the block near the knock sensor, might be hard to get a reading that close to the exhaust.
soo if the gauge matches the thermometer read. Is there any other reason why this thing is running so cold… cavet I didn’t own this truck last winter. Could this be its norm? |
Dash reading 160-170. One line above the 1/4 mark
IR temp gun: heater core inlet hose 171 thermostat housing 179 so I’m thinking the gauge is correct |
(Post 755749)
Been swapping out thermostat and trying that rubber o ring thing in different ways still can get any hotter.
(Post 755753)
https://cimg4.ibsrv.net/gimg/blazerf...d7d258e5f5.png
This goes around the as it sits in the depression on the block |
| All times are GMT -5. The time now is 02:21 AM. |
