when the truck is experiancing the issue open the hood and feel how hot the ign coil is. Maybe it's getting weak?
Sounds like something is messed up that isn't used in open loop but used in closed loop after warmed up. If i am thinking right there are 2 temp sensors on the vehicle, one for gauge and one for the ECU. I would suspect the one for the ECU, someone with a scan tool with data display could easily test it. It's also possible to ohm them out with a multimeter |
Originally Posted by AndrewO1991
(Post 596264)
Has fuel pressure ever been checked? Fuel filter ever been changed? Any check engine codes? |
Originally Posted by burned
(Post 596281)
I believe that year only has one sensor for the computer and gauge.
I replaced the "engine coolant temp sensor" and fuel filter about a month ago. And No Codes pop up. No Engine light or nothing.
Fuel pressure was at 60psi when started up. The needle shot way past, then settled. 60psi is where it set, then would drop to about 55psi after about 10min of idle. I know there is a 65psi minimum. But if the problem is the fuel pump, "would this be the cause of my symptoms"? |
My 99 is doing the same thing. Can u please post up if you figure out what it is?
Originally Posted by tondox1
(Post 596296)
Fuel pressure was at 60psi when started up. The needle shot way past, then settled. 60psi is where it set, then would drop to about 55psi after about 10min of idle. I know there is a 65psi minimum. But if the problem is the fuel pump, "would this be the cause of my symptoms"? Correction with the PSI readings. They are as follows; 1st switch, eng off - jumps to 64psi then falls to 54psi 2nd switch, eng off - jumps to 64psi then falls to 54psi start car - sits at 53-54psi slow rev to 2000 rpm - holds steady @ 53-54 psi punch pedal down real quick - jumps to 64psi idle for 5min - vehicle runs steady at 53-54psi turn off engine - spikes up to 64psi then falls to 57psi engine off for 10min - falls down to 45psi |
Problem, needs to stay above 55 for ten minuets with key on engine off. May not be only problem but it is a problem. |
Originally Posted by spittybays
(Post 596350)
Problem, needs to stay above 55 for ten minuets with key on engine off. May not be only problem but it is a problem. the thing that throws me off though, is that my truck doesn't sputter/die after idling too long. And the sluggish acceleration is only consistent after it is warmed up but disappears when it has been turned off for a while. I don't like messing with fuel, so I'll take it to a local mechanic and have them do a Fuel Pressure test and Fuel Pump test professionally by themselves. I pray that they find something less expensive ! lol |
Originally Posted by 99blazerdog
(Post 596330)
i'll definitely post my results. |
I just replaced my fuel pump last week and mine is still doing what yours is doing
