Lower intake gasket replacement
Morning Everyone,
I was on here the other day and found a very descriptive procedure on replacing the lower intake gaskets. I can't seem to locate that thread now. It was very nice with pics and certain tools needed. Can anyone post a link or something? Thanks |
Found it, thx anyway
Check this site as well, very helpful
How To Replace Intake Manifold Gaskets On A GMC Jimmy 4.3 Liter V6 To Fix A Coolant Leak - GM Truck Engine Repairs |
Originally Posted by 0ffroader
(Post 665196)
How To Replace Intake Manifold Gaskets On A GMC Jimmy 4.3 Liter V6 To Fix A Coolant Leak - GM Truck Engine Repairs A few additions, and one recommendation. The bolts for the lower manifold have to be tightened in proper sequence, in three separate steps. The actual torque specs are 26 inch pounds for the first step, 106 inch pounds for the second step, and 132 inch pounds for the final step. I'll see if I can scan or photograph the diagram with the order, but you criss-cross, working from the center out. The bolts are "replacement recommended." Personally, I'd never reuse the original bolts, and I strongly recommend stainless steel replacement bolts. ARP makes a set specifically designed for this application (ARP part # 434-2002), or you can get 8 good quality stainless bolts, 5/16-18 x 1.5 inches long, with smooth flanged heads. Install the bolts with aluminum anti-seize on the threads, and on the bearing surface of the bolt head flanges. Anti-seize (not thread locker) is even more critical if you use "stock" or aftermarket replacement bolts that are not stainless. |
Well I wasn't going to replace the bolts but I may now. It seems like I've seen both methods discussed here. I may be mistaken but I thought someone said use medium thread lock, someone said use a good sealer and you recommend anti seize.
That makes me a little confused :) Later p.s. Thanks for the info and the links! |
Originally Posted by Graveyard
(Post 665225)
alrighty, I like those explanations. I've been a machinist for over 35 years now and the anti seize makes sense. One more question...I think,lol, should the lower intake gaskets be installed with both surfaces clean and dry...nothing but gasket other than each end where you have to use the tube of sealant?
The factory service manual, at least for my 99 blazer, specifies that thread sealant be used for the intake manifold bolts.
(Post 665236)
That is exactly the kit I have. I just ordered the ac fuel injector kit and a new upper plenum, mine has a crack in the rear passenger corner.
Did you see a nice improvement on performance with the new parts? |
| All times are GMT -5. The time now is 04:16 PM. |
