MAP help !!!
My buddy is on the side of the road. He had a map sensor code 2 weeks ago, changed and ran fine until now. Shut off with same code and symptoms, won't start, need to know what plug on the pcm has the MAP 5 volt ref wire and the wire color ????
Never mind found on this site |
The wiring diagram can be found in the link below:
P1107 - MAP Sensor Circuit Intermittent Low Voltage |
