Max Ac switches to Defrost on Acceleration
Old Oct 30, 2010 | 07:38 PM
armydad71's Avatar
armydad71 is on a distinguished road
Default Max Ac switches to Defrost on Acceleration
When I have my Max AC on and accelerate my vents switch to the defroster vents and when I let off or drive at constant speed it come out of front vents again. I am thinking vacuum leak but havent found one. Also my fans in any selection sounds like a moan and air flow restriction....
Any help guys....thanks in advance.
Old Oct 30, 2010 | 07:43 PM
69chevelle's Avatar
69chevelle is on a distinguished road
what do you drive?
sounds like vacuum reservoir. on the newer ones it's mounted in the drivers side fender. check for an unhooked line by the abs box.
older ones there is a black ball, it could be cracked(leaking) as well
Old Oct 30, 2010 | 08:26 PM
If air flow goes to defrost on acceleration only when it's set to the MAX AC position, (all other modes are OK) the recirc actuator circuit has a vacuum leak. That is the only position that the recirc circuit has vacuum applied. If there was a vacuum leak anywhere else in the system, it would act up in other mode positions. The vacuum line from the mode switch to the recirc actuator is orange. The actuator is located in the dash just above the passengers feet.
Old Oct 31, 2010 | 05:46 AM
armydad71's Avatar
Sorry it is a 97 Blazer. Mine has a ball on the hood. I will try and find a leak as well.
Old Oct 31, 2010 | 12:10 PM
Same diagnosis holds true for 1997. Check for leaks in the orange line from the mode switch up to and including the recirculate actuator diaphragm.
tdbone1
Dec 20, 2012 09:40 AM
lovemy01ZR2
Performance & Brainstorming
13
Mar 21, 2010 10:35 AM
Beaner 88
Sep 2, 2008 05:46 PM
TripleBlackBlazer
Feb 4, 2008 02:34 PM
mdehoogh
Sep 7, 2007 05:27 AM
