Missing HANGER on Catalytic Converter
1998 Chevy Blazer S10 with 4.3L V-6, 2-wheel drive, 4-door
The Cat needs to be replaced so I ordered a . However, when I climbed under the vehicle I noted that the OEM Cat has an additional hanger next to the front flange just like the . I also note that the also does not have the front hanger just like the MagnaFlow. So my question is: Is the front hanger necessary and if so why doesn't the MagnaFlow nor the Walker come with the front hanger welded in place? Is the front hanger just not necessary or is it expected that you need to take it somewhere to have the additional hanger welded in place? One would assume a Direct Fit Cat is infact a direct replacement not requiring any additional welding. Anyhow, I already have the MagnaFlow Cat in hand and am wondering if I should go ahead and install it even though it only has the rear hanger but not the front hanger like the original Cat currently in the vehicle. |
Not really qualified to respond on the hanger, but did want to tell you that I have the mating 3 bolt flange pipe for the muffler that I did not use when I had my 95. So if by chance you need this, yours for the shipping cost.
Email is deanvette@comcast.net. |
Thanks for the generous offer but I think I'm in good shape for that component. If I find I need one I'll let you know. Thanks again.
Hopefully, someone with some knowledge and understanding of why the MagnaFlow and the Walker do not come with forward flange hanger can chime in. |
