-   -   Missing/Shaking at idle... (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/missing-shaking-idle-97603/)
KTS Aug 26, 2018 02:05 PM
OK, all changed.....but, now I have 3 new codes, and it's still running bad.
Codes: P0122...P0300...P1351
Blazer18 Aug 26, 2018 02:22 PM
I read that you had the upper intake off the change the spider injector assembly so my question to you is did you plug the ignition control module back in? p1351 is a icm voltage high code. P0122 is a throttle position sensor code. Double check the connectors on those.
