Are Moog CK control arms as good as OEM?
It's time for those upper control arm bushings once again and I'm more inclined to buy an entire control arm this time around.
I see them on rockauto for 80 a piece for the arm with bushings and problem solver ball joints installed. Gonna cost me about the same to get the bushings separately and have someone press them in. Any feedback? |
They are about as good as you could get unless you buy OEM. However, make sure you get the ones that can be greased.
I didn't think you could still buy OEM unless you mean the AC Delco Professional.
Originally Posted by dlundblad
(Post 691772)
Pretty much, that is what I mean. |
So AC Delco professional is better than the moog? I heard the moog bushings are way better but I have no idea about how good the actual arm is
I have found Moog to be very good but in at least one case had some dimensions bigger and made the fit a little tight (idler arm).
George |
I did a mix of Moog, Raybestos professional, and ACDelco on my front end a few years ago and it is still doing well. I would say, unless ACDelco is the same price and availability you can't go wrong with Moog. I also have Moog tie rod ends and ball joints on my corolla and my wife's forester. They are all experiencing no issues.
| All times are GMT -5. The time now is 07:40 PM. |
