MPI conversion done but ????
I was wondering if anyone has had this issue ,after i installed the updated mpi spider fuel injection system the truck stumbles slightly off idle when accelerating !!! I installed a new cap and rotor (ac/delco of course) also i replaced the plugs with the recommended plugs!! Its not that bad but kinda annoying !! I thought maybe a vacuum leak ??? I will check that when i get a minute !! any ideas???? Thank you!!!
I forgot to mention that i no longer have spark knock with regular gas !! I was running midgrade and premium to avoid that !! $$$$ costly!!
You didnt mess with the throttle stop screw, did you?
BIG No-no! And I assume you didnt mess with the distributor. So maybe just needs to relearn. But it does sound a lot like a little vacuum leak. |
No i didnt remove the distributor or mess with the throttle stop screw !! it runs goods i wish the idle was a little smoother but i know these 4.3 motors are rough runners!!
vac or air intake leak after the mass air sensor. like o=ring on air intake at tb? vac hoses vents look it all over. i suspect more a leak before tb than anything. remember if the engines using air the mass air isnt detecting itll run lean and hesitate. check that vac tree by the pcv valve too, the one that turns into the upper plenum with a 1/4 turn make sure u put the o ring on it (the brake booster hooks up here)
Originally Posted by blazer chris
(Post 469606)
Can you see the engine move at idle.. or feel it? Another symptom of vac leak. |
Originally Posted by trucktom
(Post 469773)
Originally Posted by pettyfog
(Post 469799)
???? They are? Cant prove it by me. What are you comparing it to? And what is your idle rpm?
i think not understanding, of course check everything. but main concern imo is the big 4'' oring on the plactic air horn on top of the tb going to thr air cleaner. check it all but if runs ok and just hesitates then i would look first for a leak between tb and mass air sensor,making it lean and hesitant
Thanks i never thought about the tb to air cleaner connection i just assumed it was never gonna leak there !! i will check that !! by the way i just checked and i got 17.5 mpg about the same as i was getting with the old spider!! but if i can find out what is causing the stumble maybe that will help mpg!!
| All times are GMT -5. The time now is 07:22 PM. |
