Multiple door mounted items not working
RE: Multiple door mounted items not working
ORIGINAL: dBsound
When removing the door panel, make sure you find the two bolts that pass thru the door handle. The IDIOT that previously owned mine, took the door apart, and apparently wasn't smart enough to find the two bolts, and RIPPED the door skin off, leaving the bolt hole parts, and the bolts. I'm still occasionally gerry-rigging it, trying to keep it on tight.
^^^Your name's not Eric Lines, from Indianapolis, is it?
LOL.
And it's damned hard trying to find something that will fit in the bolt holes, to hold it. I've got two large washers up in there now, but they barely hold it. I'm just hoping it'll hold until it warms up.
I really need to invent some "cone shaped" thingamabob, that will grab the remaining plastic.
LOL.
ORIGINAL: dBsound
LOL.
LOL.
Epoxy to what? That's the problem. The plastic where the holes WERE, is gone, so there are two BIG holes now. The "tunnels" that lead there are, IMO, the best hope for a positive grab. A small cone, with a bolt hole in the end, would grab the tunnel!
I guess maybe if I completely removed the door skin, MAYBE a washer could be epoxied to the plastic, from the backside.........
ORIGINAL: dBsound
LOL.
LOL.
Can anyone help with the electrical issue?
Is your only problem the windows? Can you lock the doors from the passenger door?
The door locks work fine from either door. My Blazer has the window lock feature so that you can control whether the passengers can roll windows up and down. I'm not sure if that is standard, but mine has it and the window lock can be in either position and the other windows still will not work. The will only work from the drivers switches. Thanks for the help!
Sounds like your master switch (what is on the driver door) has a fault in the window lock out. I would grab another switch from the junk yard and swap it in.
IMO if your windows roll up and down, I would leave it alone. I hate when people mess with my pass. window anyway. LOL.
mjw1991
02-24-2013 10:18 PM
dannyek7
06-04-2010 07:53 PM
95POSmoneypit
09-21-2009 02:17 AM
