-   -   MY 97 262 Vortec valve rocker arm installation (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/my-97-262-vortec-valve-rocker-arm-installation-81438/)
monette999 09-02-2013 08:38 AM
2 Attachment(s)
Dear Forum,
I am assembling my Vortec 262 engine together and having a disput with the valve lash adjustment.
how to adjust the rockers.
I see other prosposal with firing order procedure.
The GM porcedure says
Put the engine on TDC Cyl. 1 mark and then tighten all rocker nuts with 25Nm. Donīt turn the crankshaft !!
Ist this correct.
BR
Bob
The GM Service Manual is saying:
4. Apply prelube GM P/N 12345501 or equivalent to the valve rocker arm and valve rocker arm
ball bearing surfaces.
5. Install the valve rocker arms.
6. Install the valve rocker arm balls.
Important:
Once the valve rocker arm nuts are installed and properly torqued, no additional
valve lash adjustment is required.
7. Install the valve rocker arm nuts.
8.
Rotate the crankshaft balancer to position the crankshaft balancer alignment mark (1) 57–63
degrees clockwise or counterclockwise from the engine front cover alignment tab (2).
9. Tighten the valve rocker arm nuts.
Tighten
Tighten valve rocker arm nuts to 25
Y (18 lb ft).
burned 09-04-2013 11:11 AM
Correct, there is no lash adjustment. Just torque to the correct spec.
James Getter 04-12-2014 12:41 AM
question i have see it says 57-63 when titgtning rocker arms i am new to working on the 4.3 and just did head gaskekts i have a 2001 do i just tighten them to 20 ft pds or is 57-63 for the 2 timing marks on the harmonic
