My dash vents are not working, heat only blows on the floor, why?
Old Jan 19, 2010 | 12:11 PM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
Default My dash vents are not working, heat only blows on the floor, why?
on my 95 S10, the dash vents will no longer blow air out of them when you switch it to the vent position. this problem just started yesterday. now it doesn't matter if its hot or cold air, it just blows on the floor only. the blower motor works fine and so does the speed of the blower motor. whats wrong? why can i no longer get it to switcg positions from the floor to the dash vents?
Old Jan 19, 2010 | 12:13 PM
You could have a vacuum supply problem to the HVAC control head. That is where I would start looking.
Does your 4wd work?
Old Jan 19, 2010 | 01:15 PM
lucky 13 performance's Avatar
lucky 13 performance is an unknown quantity at this point
its a vacuum line.
mine had the same problem until yesterday.
would only blow in the defroster setting. blower worked fine as well as the speed.
found a hole in one of the lines and now it works fine. and i have my 4x4 back
Old Jan 20, 2010 | 11:26 AM
Kemp's Avatar
Kemp is on a distinguished road
Look for the "t" in the vac line behind the abs under the hood. Remove it and blow through it, might be clogged. Also check vac lines for holes/pores. My "t" was clogged with dirt, but it all came from a problem with tranny fluid in my vac lines. Faulty output shaft seal.
Old Jan 20, 2010 | 11:32 AM
bigkhans's Avatar
bigkhans is on a distinguished road
Check that vac cannister on the fender well for holes, if you find one put some silicone on it.
Old Jan 20, 2010 | 11:56 AM
hubert hefner's Avatar
hubert hefner is on a distinguished road
i had that same problem when i bought mine. There is a vaccum ball mounted to the underside of the hood and the line on mine was dry rotted. i replaced the line going to the ball and to the T that fixed it for me and got my 4x4 working again.
Old Jan 20, 2010 | 12:35 PM
bezerker's Avatar
bezerker is on a distinguished road
Interestingly I have a similar problem, except my 4x4 works.
Would it still be vacuum related?
Old Jan 20, 2010 | 01:31 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
It probably is only I would check the actuator under the dash. There are check valves in the system that might help isolate the leak. The best tools for troubleshooting this stuff is a hand held vacuum pump (like a Mity-Vac) and a manual with a vacuum schematic
Old Jan 20, 2010 | 04:33 PM
update: ok i found my problem and it was my fault. i forgot to hook back the vacuum line behind the CPI intake when i worked on the distributor...i hooked the line back up and now the vents works. thanks guys for your advice. thats what made me look back there...
Old Jan 20, 2010 | 05:00 PM
We have an honest man at least.
