Need Help
I have a 98 chevy blazer 4wd engine code w im looking for 2 abs wheel sensors for front left and right , they are very expensive where im located can someone direct to a place where i can get these for a great price thanx!
RE: Need Help
Where are you located? This may have a bearing on where we refer you to...
*Moving to 2nd Gen Tech* |
RE: Need Help
im in rochester ny i only need the abs wheel sensors for right and left i dont need wheel hub assembly!
RE: Need Help
Hmm Not too far from me. Well, if you don't mind going hunting for them, you could try some of the local junkyards. I have a great one about 20 minutes from me, but it's in Auburn which may be a bit far for you depending on where in Rochester you live.
What is wrong with your current wheel speed sensors? If the wires have been broken/torn/crushed like so many stock WSS, you can repair this with a bit of time, a soldering iron, and some heat shrink tubing. |
