Need help with 2000 Chevy Trailblazer
Recently both my fron power seats stopped working. I can't seem to find where the fuse is for these. The heat works but not the movement. Please help me.
They are powered through the power seat circuit breaker located in the body relay block (under the driver side dash).
There also could be a problem with the main power feed to the driver seat. It goes along the floor between the firewall and the seat. It can become corroded by water in the carpet/insulation. Something else to check. You have to pull up the carpet to get to it. *Moving to 2nd Gen Tech* - The Forum Help & Suggestion Center is for forum related help specific to the software and how you interact with it. Technical questions on your vehicle will get much better visibility in one of the tech sections. |
| All times are GMT -5. The time now is 06:42 AM. |
