Need help installing distruibutor
Hi All
95 Blazer, 4 door, 4wd, 4.3 Vortec engine, 160,000 miles Ran fine but I had a P0340 code. I changed the camshaft position sensor. To do this I had to pull the distributor. The screw heads were stripped and there was no other way to get the old sensor out. I was careful to mark the position of the rotor and reinstalled it exactly the same way - or so I thought. It started hard but would run once started. It did sputter some while running. SES light was still on but now I was getting a P1345 code. According to my Haynes manual this can be caused by an improperly installed distributor. I pulled the distributor and advanced it one tooth. It wouldn't start at all. It didn't even try to start. I tried to retard it 2 teeth but I got all messed up and lost where it should be. I followed the instructions in the Haynes manual to get it set right. I removed the #1 plug and turned the crankshaft with a wrench until I felt air comming out the spark plug hole. I continued to turn the crankshaft until the timing mark on the balancer is aligned with the V mark on the cover. I marked the correct location on the distributor - the 6. I installed the distributor so the rotor pointed at this mark when installed. Still wouldn't start. I did the whole procedure a second time and still nothing. I checked and everything is connected properly: spark plug wires in the proper order and tight, sensor is hooked up, no loose hoses or wires. I am at a loss. Did I follow the procedure correctly to set the distributor? I turned the crankshaft clockwise looking at it from the front. Is this the proper direction? The distributor rotated clockwise looking down from the top so I think this was right. Is there anything I can do other than to start moving the distributor one tooth at a time until it works? Thanks Mike |
A simple search for distributor timing would have found you this.
https://blazerforum.com/forum/showthread.php?t=24373 |
Thanks for the quick reply. I searched for distributor and didn't find what I needed. Your link is right on.
The Haynes book doesn't say anything about a second mark on the balancer. I'll give it a try and hopefully it works. Thanks again Mike |
Success! and still scratching my head.
Well, I gave it another go last night with the info about the two timing marks. Still wouldn't start. I tried it several times because I wasn't sure if I was doing it right. Nothing. I then tried moving the distributor one and two teeth foward and back with still no luck. Today I got my cousin to help. He couldn't understand why it wasn't working either. Then he suggested using a wire in the #1 spark plug hole and feeling for when the piston was at the top. The timing marks were nowhere close. They were 90 degrees off. With nothing to lose I set the distributor with the piston at the top by feel. It fired right up, runs good and no codes. So now I'm a happy camper but what the heck happened to this car that the timing marks on the balancer would be wrong? Mike |
Some times the outer ring on the balancer can slip or move its possible yours has done that. I dunno but you got it and thats what matters right.
| All times are GMT -5. The time now is 07:10 PM. |
