need help replacing door bushings
Old Mar 8, 2005 | 03:21 PM
joshsamson01's Avatar
joshsamson01 is an unknown quantity at this point
Default need help replacing door bushings
I have never done this before can anyone explain the process in a way I can understand? I only have to change the driver doors stuff oh and its a 97 if that helps....thanks
Old Mar 8, 2005 | 08:54 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: need help replacing door bushings
get ready for a pain in the *** job! to put it simply, support the door with a jack (or friend), drive out the hinge pin with a punch (or they make a special tool to drive out the pin), take the old bushings out and carefully tap in the new ones. be careful cause they're very soft. you can do one hinge at a time and just move the door enough to get at the bushings. just be careful not to stretch the wires going into the door. or you can take the whole door off if you don't feel like trying to balance it while working. eithe way, its prbably going to suck and it helps to have an extra hand. good luck!
teamrojas
Dec 26, 2014 07:17 AM
Dyspayre
Jul 15, 2014 07:27 AM
9094life
Jul 20, 2010 08:32 PM
Nemo1991
Jul 5, 2010 01:07 AM
urbex
Dec 1, 2009 07:25 PM
