Need help w/ Bleeding Brakes
Old Jun 22, 2008 | 10:34 PM
uberfiend's Avatar
uberfiend is an unknown quantity at this point
Default Need help w/ Bleeding Brakes
What's the procedure for bleeding brakes and MC for a 1998 Blazer 4WD? I think my partner in crime let the MC run low when bleeding it and introduced air. I thought we had the correct procedure, but now I'm not so sure - after lots of work trying to bleed air out of the MC, the brake pedal is still mushy when testing.
Help!
Old Jun 23, 2008 | 12:10 AM
djdrew010's Avatar
djdrew010 is an unknown quantity at this point
Default RE: Need help w/ Bleeding Brakes
start with the furthist wheel away from master, Pass. rear, then the next closest, driver rear, then the next, pass. fron, then the driver front. keep checking the master af the fluid level and fill it up as needed
Old Jun 23, 2008 | 10:46 AM
uberfiend's Avatar
Thanks! (I found one of Kyle's posts for dealing with the MC elsewhere, but it seems like the same procedure works just fine.) The Blazer brakes fine after a test drive now.
Old Jun 23, 2008 | 10:55 AM
I knew I had wrote something to this affect up at some point! LOL Glad you got it all figured out and fixed up!!
mikede123
Sep 20, 2011 11:32 AM
upmaine
Aug 28, 2010 07:56 PM
toaks1
16
Jan 20, 2010 08:12 AM
flamez2647
Jul 28, 2009 09:40 PM
chvygirl84
Nov 20, 2008 08:45 AM
