-   -   Need help w/ Bleeding Brakes (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/need-help-w-bleeding-brakes-21465/)
uberfiend Jun 22, 2008 10:34 PM
What's the procedure for bleeding brakes and MC for a 1998 Blazer 4WD? I think my partner in crime let the MC run low when bleeding it and introduced air. I thought we had the correct procedure, but now I'm not so sure - after lots of work trying to bleed air out of the MC, the brake pedal is still mushy when testing.
Help!
djdrew010 Jun 23, 2008 12:10 AM
RE: Need help w/ Bleeding Brakes
start with the furthist wheel away from master, Pass. rear, then the next closest, driver rear, then the next, pass. fron, then the driver front. keep checking the master af the fluid level and fill it up as needed
uberfiend Jun 23, 2008 10:46 AM
Thanks! (I found one of Kyle's posts for dealing with the MC elsewhere, but it seems like the same procedure works just fine.) The Blazer brakes fine after a test drive now.
swartlkk Jun 23, 2008 10:55 AM
I knew I had wrote something to this affect up at some point! LOL Glad you got it all figured out and fixed up!!
