-   -   need some help my driverside door keeps coming unlocked (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/need-some-help-my-driverside-door-keeps-coming-unlocked-74855/)
bobby099 10-29-2012 02:53 PM
i have a aftermarket alarm but when i set my alarm everything seems locked then after hours i go to unlock my blazer the door is unlocked on the driverside. i have a 98 blazer
trobbins 10-30-2012 09:49 AM
try posting this in the electronics section you find alot more help there and try an research
swartlkk 10-30-2012 09:54 AM
No need to repost the question in another forum (which is against forum rules BTW).
It sounds like you need to spend some QT with your truck and determine how/when the door is becoming unlocked and then determine the cause. Phantom unlocking is not a common problem and since you have aftermarket equipment, the only solution is to actually sit down with your truck and observe. Maybe it is a weak door lock actuator not fully seating the lock (doubtful). More likely, the aftermarket alarm is unlocking the door for some reason.
Will the door stay locked if you disconnect the alarm?
bobby099 10-30-2012 07:04 PM
ive been messing with it all day and ive sat in it for hours with the alarm on lock and nothing but once i get out and lock it again it and go back outside to get back in it the door is unlocked
trobbins 10-30-2012 09:07 PM
do you know what setup you are using?
bobby099 10-31-2012 08:02 PM
Avital 5303L that is the unit im using, but ill give you guys some more things ive noticed the unlock and lock switch panel is not working but the window switch works im not sure if maybe something is just loose in the wiring.
trobbins 10-31-2012 10:18 PM
so when the door appears to come back unlocked is it after you manually lock it or do you lock it with the keypad buttons
bobby099 11-01-2012 06:53 PM
its after i manually lock it.
trobbins 11-02-2012 08:59 AM
when car is locked does it show up on your keypad that its locked
Jamclark 11-09-2012 01:18 AM
I have no strong recommendation on that, but sure there are lot of members who have huge information about lock system.
Moreover, you need to check its manual as well as wiring system.
