needin AC wiring schematic
well i had a previous problem on here with a fuel pump issue that was rare and hard to solve that i was gonna update,, but my threads are deleted, oh well, same truck more problems. Ac not kicking clutch in after charging system or trying to charge it. jumped low pressure switch , nothing happened. checked my chiltons manual and only wiring shown is where it leaves the control module. anybody happen to have a more complete wiring diagram? thanks
I would first recommend vacuuming the system down then try charging it, check the plug that plugs into the front of the clutch pull it out and use a test light on it to make sure you are getting power to the clutch, then proceed to re-charge the system and check your results, you can try replacing and jumping relays which are located on the firewall of the engine but that is a last resort, see what you come up with the test light at the compressor clutch
check the high pressure switch to. mine didnt work cuz my high pressure switch was bad just a thought
Hey, thanks for replys, i am not getting voltage at the clutch, thats the reason i need a wiring schematic. any further help is appreciated.
thanks
thank you so much, i couldnt find that anywhere on the internet. ill update when its running.
