-   -   New Jasper Engine, high oil pressure (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/new-jasper-engine-high-oil-pressure-41498/)
Skeeter Cruz 02-28-2010 04:10 PM
Hey guys. Finally finished a six month process of putting in a new Jasper motor and rebuilding my tranny with a Monster SS package (I'm in school and working - not a lot of free time). Anyway, read through an old thread and figured out I had the distributor 180* off (thank you Kyle) got that fixed today and it finally fired right up! But it's running high oil pressure, gauge almost all the way up. I only ran it for about ten seconds and then shut it off because of that. Is that normal for a new car firing up (maybe it's pressurizing the lines?) or is something wrong?
Thanks.
1998 Blazer, Jasper engine, 4.3L
Quik 02-28-2010 04:17 PM
fresh motors usually have higher oil psi till they break in
Skeeter Cruz 03-01-2010 12:03 AM
Thanks. So I shouldn't worry about it and drive it?
Skeeter Cruz 03-01-2010 01:38 PM
Little help? Sorry about being annoying, but I want to drive this thing!
swartlkk 03-01-2010 01:50 PM
As quik said, it is normal for a new motor to show higher than normal oil pressures. If it sounds normal, I don't think I would worry too much about it.
One question I have is did you verify that the gauge is reading properly by hooking up a mechanical gauge to it? The factory gauge isn't a linear transition and really isn't all that accurate to boot.
Skeeter Cruz 03-01-2010 07:48 PM
No, I didn't. I'll look into that. Thanks!
