New from tampa,fl couple if questions.
hello everyone I'm a new blazer owner from Tampa,fl.I Traded my 98 ford contour (aka)nightmare for a 98 blazer ls 4door 4x4. my car needed a tranny and the blazer needed motor work.I have a daughter and i needed something bigger.So i have a few questions.1st the truck turns on fine but the bottom end starts makin a loud almost squeeling noise,it has oil psi but low ithink its a main bearing. should i buy a crank kit for 300 and hope tnats all it needs or should i rebuild the whole thing,or Get a motor from a salvage yard for $600 with 90 warranty.2nd question ive been doing reseach and if i swap my stock 4x4wheels with stock 2x2 wheels the rear wheels will stick it out abit.my question is,there a way to get those wheels to sit flush.also is it noticible.thank you in advance for the helphttp://i286.photobucket.com/albums/l...c44a321fa3.jpg
welcome from New Orleans, and try surfing the forums for answers, sometimes it's a lot quicker than waiting for an answer, and there is a wealth of useful information on this site and lots of smart people
Welcome from VA!!
Welcome from Utah.
welcome from ny
thanks to all
Welcome from michigan.
If it were me i would swap out engine..might be more in that hole once you jump in it...but search around.....has been ran into here before |
*Moved to '2nd Gen Tech' since the 'New Member' section is only for introductions*
in the bay area too..
What part of tampa?I'm from ruskin
| All times are GMT -5. The time now is 02:27 AM. |
