No interior lights - no power to the sockets
I just bought a 2001 GMC Jimmy. None of the interior lights work. They don't work with the doors open, closed, with the switch on, over-ride off, etc. Also, the bulb was removed from the socket for the under hood light. I tested the light sockets with a test light but there's no power to any of them.
It's possible some previous owner removed the bulb under the hood in an attempt to stop a battery drain problem, but I don't know. There's no power to it, so the circuit was broken somewhere else. Now that it gets dark early it has really been annoying not having any interior lights. How should I go about troubleshooting this? |
3 Attachment(s)
Originally Posted by Rathbone
(Post 728969)
Did you check the fuse? I would assume you did that first, but you didn't say, so I had to ask.
Thanks for the PDFs, I'll read those.
I looked at the fuses, but I don't know specifically which one applies. I don't have the owner's manual. |
What's an IP Compartment?
(Post 728998)
Well, now I feel stupid. I didn't notice the fuse panel on the side of the dash. I was looking at the fuses under the hood. The fuse was blown. Replacing it fixed the lights.
Don't beat yourself up over it. We all overlook the obvious once in a while.
Glad you got it fixed. 👍 |
| All times are GMT -5. The time now is 07:16 PM. |
