No power to any thing
Old May 24, 2010 | 07:33 AM
potts's Avatar
potts is on a distinguished road
Default No power to any thing
I have a 95 that I just finished replacing the head gaskets on went to start it and got nothing. I could not get any electrical at all. No lights, no crank not one thing electrical working. I have not checked the fuses in the distrub center.
Old May 24, 2010 | 07:38 AM
Survivor's Avatar
Survivor is on a distinguished road
Check the Main engine ground. It is located on the passengers side of the engine block on the front face, near the bottom corner. GM has been known to install star lock washers between the block and the ground wire. After a few years of soot just slight wiggling of this wire can cause this.
Old May 24, 2010 | 09:28 AM
potts's Avatar
I hit the battery to block with an ohm meter and it has a good ground. The cable is clean and has good connection. I put on a new positive cable because the other was full of crap. I had the battery check and it is good. It will turn over another truck, so that is not the problem.
I have not checked the main distrubution panel for power.
dp
Old May 24, 2010 | 11:39 AM
Well, check the main distribution block for power...
Did you check continuity on the main positive battery cable?
Old Oct 3, 2010 | 10:12 AM
perplutt's Avatar
perplutt is on a distinguished road
Hi,
I have the same problem as "Potts" has changed the intake gasket and now the Chevy is completely dead, nothing works, neither light radio yes everything is dead.
help me someone
Muddigger86
Feb 8, 2014 09:41 AM
MuddBunny84
Shows & Clubs
Jul 9, 2010 03:39 PM
johnwiseman
Lifting Tech
Nov 3, 2008 09:51 PM
Hanr3
Sep 21, 2005 05:05 PM
