-   -   No primary voltage need schematics (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/no-primary-voltage-need-schematics-48529/)
big_windy 08-30-2010 07:24 PM
Can anyone help me get the ignition chematics for a 4.3ltr 2000 blazer with EDI ignition?
I just changed the timing chain and gears on the truck, and may have wiring problems because I had to raise the engine to remove the pan. Any help will be welcomed, Thanks.
swartlkk 08-30-2010 08:50 PM
What parts of the ignition system do you require schematics for. My references have it split up by sensor, etc, not a whole system diagram...
Also, you could always consider a subscription to AllDataDIY.com.
big_windy 08-31-2010 07:12 AM
I'm interested in harness from Crank positioning sensor and coil/control to PCM. I'd like to check for voltage/ohms in these wires.
swartlkk 08-31-2010 10:57 AM
1 Attachment(s)
I was able to locate one diagram that has all of this in it.
big_windy 09-01-2010 06:54 AM
Super! Gotta work today, but will hit the garage tonight to begin troubleshooting. Suspect the PCM is going, but had no codes to that direction. I figured with the amount of miles, it'd be a safe bet the timing needed a going through.
Man, that was a tough job!
Thanks Swarty!
