-   -   No tail lights (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/no-tail-lights-76441/)
neemo6 01-11-2013 10:41 AM
No tail lights
Im having an issue right now with now dash or tail lights. Strange this is that they work fine when the truck is started w/ the remote start unil the brake pedal is tapped. Any ideas as to where to even begin to look?
Smitty Smithsonite 01-11-2013 10:54 AM
Under hood fuse box, for starters. Might just be a popped fuse ... but then you'll need to figure out why it popped. Have any aftermarket lighting out back? If so, that would be the first place to check.
Here's a tip to save your fuse supply .. and your sanity -- wire up a light, and stick the wires in place of the fuse. If the light lights up bright, like you stuck it to the battery, then there's a short in that circuit. Remove or unplug wires in that circuit until the light gets real dim or goes out altogether.
01-11-2013 02:48 PM
Unplug everything from your remotstarter module and a new fuse. See what happens.
criadoman 01-15-2013 11:10 AM
Actually there is another item that can cause this. Apparently in our model of Blazer the circut for the taillights comes through the Hazard switch. There was a recall issued some years ago on this. I replaced the Hazard lamp switch and have had no problems since. Hope this helps. By the way, a tell on this is that the brake light works and tail lights dont.
