-   -   Nut Kit "technical" or "proper" name? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/nut-kit-technical-proper-name-35598/)
midnightmekanik 10-07-2009 08:43 PM
So I've narrowed down my problems with warm starting to either a leaky fpr or nut kit. I figure if I'm going in there I'll do both. I only have one problem... No one around here seems to know what a "nut kit" is?? I haven't cracked the IM to see the part for myself, so I couldn't even tell the parts person if its the wrong part (I usually have to LOL). What is the actual name? Even better would be a link to pictures and such?
Thanks.
male1956 10-07-2009 09:47 PM
this help ?
http://www.aztpi.com/product.php?pro...3&cat=0&page=1
reelbroke2 10-07-2009 11:55 PM
the nut kit is also called the fuel return lines
Jason Rebellion 10-08-2009 12:44 AM
warm start could also be a coolant temp sensor going out. it dumps more oxygen into the intake to start it up cause it reads as cold.
midnightmekanik 10-08-2009 12:06 PM
Thanks guys... I'm still having an issue finding it locally. I haven't checked the dealers, and won't considering previous times checking prices they really gouge you here...
Jason, it's not the coolant sensor, I'm getting too much fuel, and my fuel pressure drops quickly after the engine is shut off.
reelbroke2 10-08-2009 03:23 PM
if you cant find it locally check e-bay i just searched blazer fuel return lines and there are alot listed that will ship to your neck of the woods...good luck
midnightmekanik 10-08-2009 06:38 PM
I've checked ebay... It only lists up to 95 models. I have a 97. If it's the same (I don't think it is) I'll gladly pick it up...
EDIT : I may be retarded today... Do I even need to get this part for a 97?? I can't find anything after 95 model years??
swartlkk 10-08-2009 06:47 PM
No, you do not need this part on a '97. This is only for the CPI motors which were discontinued after the '95 model year. In '96, the SCFI engine took the place of the CPI engine.
midnightmekanik 10-08-2009 08:32 PM
See? Told you I may be retarded today LOL...
Thanks for clearing that up Swart! Saturday I take on the task, will let everyone know how it goes!
Thanks to everyone for their wasted time :icon_doh:
