o2 sensor bank 1
I have a 2001 chevy blazer 4x4 2door and i had a code say bad 02 sensor bank 1 does anyone have a picture of where it is or how to change not very sure how to do it?
RE: o2 sensor bank 1
What was the specific code? On an '01 (any '98+), you will have:
So as you see, you have two Bank 1 possibilities. |
how hard would it be to take them all out and clean them i think there really dirty or would it just be better to replace them ?
It is highly likely that you will do more harm than good by attempting to clean the sensors. Some have had luck cleaning them though.
How I would typically diagnose this problem without using my scan tool would be to swap the sensors side to side (in the case of the B1S1 & B2S1 sensors). The B1S2 sensor is the post cat sensor which only monitors the catalytic converter and has nothing to do with fuel management. But I would have to know the actual code to recommend further. |
| All times are GMT -5. The time now is 07:09 PM. |
