O2 Sensors Driving me crazy
Ok this is driving me Nuts; I found a vacuum leak and fixed that during
that time I was getting MAP sensor errors but now I am getting all of these codes and I’m not sure if I should replace the B1S3 sensor. I was hoping to get some help from you all! Thanks in advance! View / Vehicle Trouble Log / Summary Time Vehicle Trouble Code Description Problem 1 2/10/2007 8:31 PM chevy Blazer P0174 System Too Lean (Bank 2) Problem 17 2/14/2007 9:09 AM chevy Blazer P0144 O2 Sensor Circuit High Voltage (Bank 1, Sensor 3) Problem 19 2/14/2007 10:46 AM chevy Blazer P0174 System Too Lean (Bank 2) Problem 20 2/14/2007 7:54 PM chevy Blazer P0144 O2 Sensor Circuit High Voltage (Bank 1, Sensor 3) Problem 21 2/14/2007 7:54 PM chevy Blazer P0174 System Too Lean (Bank 2) Problem 22 2/14/2007 7:58 PM chevy Blazer P0147 O2 Sensor Heater Circuit (Bank 1, Sensor 3) Problem 23 2/14/2007 8:46 PM chevy Blazer P0144 O2 Sensor Circuit High Voltage (Bank 1, Sensor 3) Problem 24 2/14/2007 8:46 PM chevy Blazer P0147 O2 Sensor Heater Circuit (Bank 1, Sensor 3) Problem 25 2/14/2007 8:46 PM chevy Blazer P0174 System Too Lean (Bank 2) Sensor 3) Problem 30 2/15/2007 8:59 AM chevy Blazer P0147 O2 Sensor Heater Circuit (Bank 1, Sensor 3) Problem 135 2/23/2007 9:58 PM chevy Blazer P0171 System Too Lean (Bank 1) Problem 136 3/10/2007 10:42 AM chevy Blazer P0144 O2 Sensor Circuit High Voltage (Bank 1, Sensor 3) Problem 137 3/10/2007 10:47 AM chevy Blazer P0144 O2 Sensor Circuit High Voltage (Bank 1, Sensor 3) Problem 138 3/10/2007 11:10 AM chevy Blazer P0144 O2 Sensor Circuit High Voltage (Bank 1, Sensor 3) Problem 139 3/10/2007 12:19 PM chevy Blazer P0144 O2 Sensor Circuit High Voltage (Bank 1, Sensor 3) |
RE: O2 Sensors Driving me crazy
Wow... You could condense that down to the 3 or so main codes you've gotten...
B1S3 is only an emissions monitoring sensor. Nothing to do with fuel delivery. We need to know a bit more about your truck though... Basic information would be the year. I can assume '96+ due to OBD2 codes, but the '96-'97 trucks had 4 O2 sensors while the '98+ have 3. |
97, v6, 4x4 106k on the mileage,
New intake gaskets 8 months ago, along with new plugs new water pump, new fuel pump, filters, basicly everything reworked. this problem just started |
| All times are GMT -5. The time now is 09:31 AM. |
