-   -   Odometer problem (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/odometer-problem-28347/)
a-dub Mar 7, 2009 12:57 AM
Odometer problem
My Odometer went out on my 2000 blazer today. The odd thing is that the trip odometer still works. Any suggestions? All other gauges function normally, and my blazer has the digital odometer, the trip button toggles between the two.
swartlkk Mar 7, 2009 02:28 PM
This is typically caused by a faulty cluster. The diagnostic procedure for this type of problem requires a Tech2 or equivalent scan tool to access the cluster and perform functional tests.
Cavalier z24 Mar 7, 2009 02:38 PM
actually this might help as well my mother has a 2007 ford focus and her digital Odometer stopped working like your and i just up plugged the battery over night and the next day it was fine so try it it wont hurt to try :P
a-dub Mar 7, 2009 07:19 PM
I should have mentioned that the odometer still displays 80997, so it seems like it's not getting a signal. A few people I asked said to check for a bad connection, broken wire or short. Someone also seemed to think it might be a PCM issue. Any other ideas? Also, I noticed that this happened immediately after I had my tires rotated at discount tire, any chance they could have knocked something loose?
