-   -   Oil Cooler / Filter Lines (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/oil-cooler-filter-lines-82256/)
cferry7 Oct 21, 2013 06:34 PM
1995 GMC Jimmy SLT 4WD
I can't locate in 2 manuals this torque spec.
Bolt Torque spec for the Bolts which attach the Oil Lines to Oil Filter Adapter and under Engine Oil Feed ?
Web page link ?
Even if it's for a similar vehicle would be sufficient for now.
Appreciate any help.
cleburne red Oct 21, 2013 09:05 PM
I seem to remember reading on here when I did mine that it was pretty light. 25 ft-lbs? I've read that if they are over torqued, it will cause the gaskets to fail, and you'll be right back where you started with oil leaks!
chris015 Oct 21, 2013 11:00 PM
not sure. done many of em. just turn till its good hand tight. then another 3/4 turn. done. dont wanna squeeze em too tight or they will leak.
Toby Hanson Oct 22, 2013 12:07 AM
I just replaced mine in the spring. The torque spec is 26 ft-lbs. I seem to recall that you don't want to overtighten them for some reason, possibly because the metal is soft and the fittings could distort.
