-   -   Oil drain plug location (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/oil-drain-plug-location-2402/)
eng69 02-12-2006 09:08 PM
This sounds like a dumb question, but where is the engine oil drain plug for a 95 blazer? 4.3 4x4. I went to change the oil, but it is not as obvious as it would seem. I can access the filter ok, but wheres the plug?
Thanks!
4lowlife 02-12-2006 09:11 PM
RE: Oil drain plug location
It may be on the oil pan, underneath the engine block.
96Ls4Dr 02-12-2006 09:49 PM
On my 96 I just bought I had to look for it a minute too.
I found mine at the rear of the oilpan facing the back of the vehicle.
*TLR* 02-12-2006 10:24 PM
i had a 95.......ls s10 4x4 , its tucked towards the back of the pan, have to really get under there to see it, as its not facing downward like most
eng69 02-13-2006 03:08 AM
ok, so its on the pan directly under the engine. I will crawl under there again tomarrow.
Thanks!
