Oil Leak Help ? Bell Housing
98 Blazer.
Leaking oil from between the engine and transmission. Dripping through the little hole in the bottom center of the bell housing. I've cleaned most of the lower engine up, and it is definately coming from the back; between trans. Any suggestions ?? Thanks |
atf or oil? either way the tranny has to come out....
its oil.
Sounds like you have a leaking rear main seal.
