-   -   Oil pressure switch location (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/oil-pressure-switch-location-94965/)
jsalinas22 07-13-2017 03:42 PM
I'm new here and need help finding the oil pressure sensor on the engine block. I have a 1999 blazer LS 4.3 v6 vortech and the oil gauge has been moving erratically, usually on a stop. I went through this forum and all I could find was this diagram Photobucket
Can anyone confirm this is the location?, thanks in advance. :icon_errrr:
newguy 07-13-2017 05:04 PM
http://www.diyforums.net/where-is-th...el-101785.html
LannyL81 07-16-2017 06:13 PM
Yep you got it. Under the distributor, driver's side. Bit of a pain to get to. Might think about pulling the distributor out for better access.
Good luck.
Bagherra 07-17-2017 09:54 AM
If you remove the distributor, wont you have to do the check also?
Tajohns34 07-22-2017 05:47 PM
I have not been able to figure out how to install it without pulling the distributor.
