ok I'm stumped
when I purchased my blazer I knew the speedo wasn't working, so I figure no problem, I've replaced the VSS on my other 2 so why should this one be so different
wrong.. first thing I did was change the VSS, still no speedo or odometer, then I removed the cluster looked for bad solder connections resoldered a few, reinstalled it, same no speedo or odemeter. so the whole time the transmission shifts prefect, I went out and tested the cruise control it's working great, so the vss has to be working am I looking at a bad stepping motor in the dash for the speedo?? |
what year blazer? it could also be the connection at the trans case, unless thats the VSS ur talking about. if not, try there......its a boxy looking thing that has ur speedo cable attached to it thats attached to the trans case. if its broke or sticky ur speedo or odometer wont work.
