Only driver door switch works the power windows...??
So I did some searching and a lot of past threads point to bad contact within the switch itself...??? But all three...??? Just like the title says, only the drivers door switch works ALL of the windows. I find it hard to believe all three other doors need switch replacement.... Thanks for any ideas...!!
Edit: The similar thread link at the bottom after I posted showed me some threads pointing to the child lockout switch... I'll give that a try and report back. |
So it was indeed the child lockout switch. All is well w the world again...!! :)
Sweet! Nice sleuthing ;)
I'm going to have to google that word bc I have no clue what it means.
I do know however that these door lock sliding things are a FPITA. Edit: Ahhhhh they go back NP on the locking position. |
I used it to mean nice detective work;)
Ahhhhh then Thank You. It surely is.
Still so much more that bothers me on this poor truck. Yesterday the drivers door hinge was squeaking so I sprayed it w WD40 and today the grommet that holds the pin tight is now missing half of itself. A loose door that doesn't close right is the result, but hey @ least I fixed a few other things as well while in there messing w window switch today. :) |
| All times are GMT -5. The time now is 12:46 PM. |
