| jrm000kc |
10-16-2019 06:35 PM |
Opinions wanted on the 'Posi-lock' cable pull
I've kept wanting to buy this to eliminate the awful vacuum system the engineer that dreamed it up should be shot for replacing the trouble free lever. However, the $150 price tag for a locking cable pull dissuades me. (It is stainless steel-much better than regular that I'd think would eventually 'freeze' from corrosion. Yes, $150 is a lot to me as I'm a working poor schlub.) The other thing I'm not sure about is changing the OEM configuration to something that quite honestly doesn't look good and when the day comes to sell a handle sticking out would make the potential buyer wonder what else I've rigged up. (Unless the buyer is mechanically inclined and totally understands the manual pull.)
Has anyone mounted this system I see in the LMC catalog? It's pretty sad that LMC even states the OEM vacuum system causes the axle locking gear to round off and not want to engage. I think my gear is rounded off as I can feel resistance the final 1/2" of travel whenever I push in the vacuum diaphragm-sometimes it locks, sometimes it doesn't after a little grinding. With the manual pull I'd think I could 'feel' what the gear is doing, also allowing me to apply more force. If it works without me having to tear the axle apart and replace the gear so much the better.
I'd love to hear people's opinions on this-along with how difficult it was to install and general longevity of the system. Reading the instructions I'm not crazy about drilling the 11/16" hole through the firewall for the cable even though they provide a bushing. Couldn't I run it through where the antenna comes through? Thanks for reading!
