outside door handles coming loose from the door
Old Dec 7, 2011 | 11:26 AM
ABSLT's Avatar
ABSLT is on a distinguished road
Default outside door handles coming loose from the door
So mainly the driver door but the passenger door is starting to do it, from all the cold winters its been through, the door will freeze, so pulling a lot harder on the door then normal to get it open, has loosened the handle, the whole plastic assembly moves about a quarter inch from the the door, still works fine, but not sure if it will last another winter Before i take the panel off, is there a way to tighten it from the inside, or will i need some new parts? 2004 4 door blazer
Old Dec 7, 2011 | 12:09 PM
Xenon's Avatar
Xenon is on a distinguished road
Subscribed. Mine does this too, curious to see what the answer is...
Old Dec 7, 2011 | 12:25 PM
pettyfog's Avatar
This should give you an idea.. though it's a different model. Handles are the same. Read close, covers both, doesnt mean you have to remove inner.
Very detailed.
HOW TO: Replace Interior and Exterior Door Handles (1997 Yukon GT) - with pix - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Old Dec 7, 2011 | 06:05 PM
ABSLT's Avatar
Very detailed.
Looks like a ton of fun, thanks a lot for the link!!
Old Dec 16, 2011 | 07:24 PM
Thommyknocker's Avatar
Thommyknocker is on a distinguished road
My newly acquired 02 blazer was doing that.
It was an easy fix. On the inside of the door there is a round plastic plug. Behind that is the small bolt that holds the outside handle on. Tighten it up.
Mine actually fell out and was in the door all the way at the bottom lol
Old Jun 16, 2012 | 04:54 PM
phillyfrank0's Avatar
phillyfrank0 is on a distinguished road
Hi, What size was the screw that tightened the handle. I tried a few machine screws but none seem to fit.
richphotos
Oct 7, 2013 08:15 PM
lannon_j
Jul 14, 2012 09:38 PM
ussexplorer
Apr 11, 2010 06:53 PM
blazin97
May 7, 2006 01:44 PM
01xtreme
Jan 1, 2005 12:59 PM
