-   -   P0155 changed part-engine light on (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/p0155-changed-part-engine-light-67527/)
shablaze Jan 31, 2012 07:10 PM
Changed the sensor (2002 blazer) but the engine light is still on with same code. Is there something else I should do to turn the light off? Inspection due in Feb. Thanks
pettyfog Jan 31, 2012 07:15 PM
So you changed the first O2 in the exhaust on pass side, right?
did you notice any burnt or frayed wires? Specifically the pink and black wires? Which should read 12v with key on.
Umm... I assume you drove it around a while, right?
shablaze Jan 31, 2012 07:18 PM
p/s behind catalytic converter - it was black and charred looking.
pettyfog Jan 31, 2012 07:39 PM
I dont understand, elaborate. What.. behind the Cat?
shablaze Jan 31, 2012 07:51 PM
the sensor was on the passenger side behind, technically after, the cat. So new one installed but light still on. does it reset automatically or do I need to do something else?
vortec bowtie Jan 31, 2012 07:55 PM
It should go off after a certain number of key cycles
war00 Jan 31, 2012 07:56 PM
fyi.... the o2 sensor behind the cat has nothing to do with fuel maps. its there to see if the cat is working properly, if you replaced the sensor, cleared the code, and it returned. than i would be making sure the sensor is recieving the right voltage and the computer is reading a voltage from the sensor and if all that checks out, than i would be looking at replacing your cat.
pettyfog Jan 31, 2012 08:00 PM
Yep.. replace the one in front {engine side} of the cat.
{cylinder} Bank 2 is always side opposite Cyl 1, Sensor 1 is always the primary O2, the one that test fuel mixture.
shablaze Jan 31, 2012 09:20 PM
ok, according to the repair manual and my neighbor as well as the parts guy guiding myself, a single mom and my teen son, we changed the correct sensor. I have only put 75 miles on the vehicle since changing the sensor.
war00 Jan 31, 2012 09:50 PM
as a licensed mechanic, unless you clear the codes with a capable scanner the light wont go out or until it has successfully cycled thru a certain number of ignition on/run/off. you can always disconnect the battery for ten minutes than reconnect it to clear the code.
