-   -   Park break light and abs light go on and off (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/park-break-light-abs-light-go-off-33495/)
ExplicitYourSelf 08-10-2009 05:20 PM
The car is a 2001 Cheverlet blazer 4dr 4.3l 2wd @ 105,*** miles. At times when i am driving and i step on the brake rough the abs light and park light will turn off. Somtimes it will turn off within Secs/mins and somtimes they wont turn off until i turn off the car. Somtimes when i am driving wuithout steepping on the break rough those lights just go on. Front and rear break pads are in good condition. Almost new. Brake fluid is at level. There is no air on the brake lines. I also noticed that when i step on the brake kinda hard I feel a vibration noise Coming from the front, It seems like it's coming from the front brakes. When the part brake light and the abs light go on they are bright, Not dimmed. Hopefully i can get some help by somone who has experianced this or just somone with some knowlage. Feedback is appriciated THNX
ExplicitYourSelf 08-11-2009 12:48 PM
Anyone??
mikeinwi 08-11-2009 12:52 PM
no need to double post if someone can help you they will, also if you would have posted in the correct section you might of received a response. you can also use the search function and see what you come up with i know this ABS issue has come up a more than a few times recently.
rriddle3 08-11-2009 01:01 PM
**moved to 2nd gen tech**
Ugly_Monkey 08-11-2009 04:01 PM
Originally Posted by ExplicitYourSelf (Post 237842)
...park break light and abs light turn on ...
Are they full brightness or are they dim?
ExplicitYourSelf 08-11-2009 06:04 PM
I will check...
ExplicitYourSelf 08-11-2009 07:41 PM
They are fully bright lit not dimmed...
mikeinwi 08-11-2009 08:02 PM
Please do not double post it is against forum rules. also if you took the time to read through this thread you would have seen this thread has been moved to the correct section for you. it is also against forum rules to create two threads for the same problem.
ExplicitYourSelf 08-12-2009 02:20 PM
Sorry obviously i wasnt paying attention. It wont happen again
