Parts
What vehicles and years can I use for parts on my 2000 s10 blazer? I am wanting to buy a parts truck.
98+ is going to be more or less the same. There are some minor differences between years, but nothing that I would consider to be serious.
98+ gmc jimmy will be the same with the exception of grille/headlight/bumper/rad. Support. Bravada is also the same, with the exception of being awd, and again the front body parts. There were options that could be different even in the same years... 4 button transfercase as opposed to 3 button, different interiors, trim packages, different gear ratio axles, zr2 suspension package, zq8 suspension package, xtreme edition, etc You can also use the drivetrain and most body parts off s10/Sonoma pickups. Just make sure they have the 4.3 if you want to be able to use the engine/tranny. |
Your best bet for a parts truck is 98,99,00 Blazer with same number of doors and same drive train (2 or 4wd). Nearly everything would be the same except the 98 steering wheel.
01 up has a different VCM/PCM. Mid 02 radios changed to double din. As ChevyRiders said there are many others with parts that will fit. |
Originally Posted by chevyriders
(Post 683477)
Thanks
Originally Posted by oldeerslayer
(Post 683478)
