Please help
Old Jan 20, 2007 | 04:20 PM
pokergirl_lynn's Avatar
pokergirl_lynn is an unknown quantity at this point
Default Please help
I have a 1995 Chevrolet Truck S10 Blazer 2WD
6 Cylinders 262 W 4.3L CPI .
I need some help. My truck was manufactured 02/95 so the computer is the older version. I have had it hooked to 3 computers and no codes display. They said it is casue my check engine light isn't on.
It runs rough, like to the point of filled fule tank went 89 miles and had to refule. It was on empty.
I have had new plugs, wires, distributor cap, rotor, map sensor, fuel filter, fuel pump, fuel injectors (5 years ago) , O2 sensor Transmisson service (2 years ago). EGR valve (4 months ago).
It is sometimes hard to start, hit the gas pedal and I blow alot of carbon out exhaust. It sputters when I accelerate, and smelling alot of fuel when I start the truck and when driving. It stalls any time I slow down. I know that it is really hard to diagnose in a forum, I hope anyone can give a clue as to what I can get checked to help.
Thanks Alot,
Lynn
Old Jan 20, 2007 | 05:09 PM
DINO55's Avatar
DINO55 is an unknown quantity at this point
Default RE: Please help
Lynn, Do you ever have any trouble starting up the engine ???
Old Jan 20, 2007 | 05:17 PM
sometimes it will start on first crank.. sometimes it wont start at all.
mostly it is I have to crank it a few times to get it running.
Old Jan 20, 2007 | 05:25 PM
DINO55's Avatar
You most likley have a bad fuel pressure regulator, Have you ever had the fuel pressure checked? If not, git it checked and that will give youyour answer.
Old Jan 20, 2007 | 05:26 PM
Thanks I will get the checked monday. You have been a huge help.
Old Jan 20, 2007 | 05:31 PM
DINO55's Avatar
Pokergirl_lynn,
Please post us back with your findings....
Old Jan 21, 2007 | 11:06 PM
where is the fuel pressure valve at? Also I changed my fuel filter and it seem to have made things worse, could that be the problem as to why hard to start, runningrough and stalling when I slow down?
Old Jan 22, 2007 | 12:48 AM
20Blazer00's Avatar
There is a small tire valve like fitting just ahead of the fire wall and behind the upper intake manifold (2000 should be the same even though you have a different intake setup). The fuel lines rise up to meet the upper intake manifold at the rear drivers side...
Old Jan 22, 2007 | 09:45 AM
DINO55's Avatar
ORIGINAL: pokergirl_lynn
Thanks Alot,
Lynn
Lynn
Is this correct? Youdid all this to the truck 5 years ago???
New plugs, wires, distributor cap, rotor, map sensor, fuel filter, fuel pump, fuel injectors (5 years ago)
Old Feb 19, 2007 | 11:56 AM
*Locked due to duplicate thread*
Please reply here: 1995 help..lol.. Again
opposedforces
Sep 1, 2011 02:59 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
blazin4eva
Feb 26, 2005 12:04 PM
blazin4eva
Jan 27, 2005 02:02 PM
